How long does it take to change a password
12-16-2018 09:27 PM - edited 01-05-2022 02:49 AM
12-16-2018 09:59 PM - edited 12-16-2018 10:07 PM
Voicemail? Self serve? Community? Phone password?
You said "change password" not "password reset" so not 100% sure...
If this is self serve...
Seconds, if you know the old password.
Longer if you need to wait for the password reset to come into your e-mail. 1-15 minutes
Even longer if you don't receive said password reset e-mail and have to wait for moderator intervention. Days.
If this is voicemail / community / phone / other item, please let us know what you speak of and we can helps you.
12-16-2018 09:38 PM
@josie2, as noted if you are not getting the password reset email promptly, you will likely not get one. You will need moderator team assistance with password reset. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
12-16-2018 09:31 PM
password changes shoudl be imidiate. if you are talking about the lost password and not getting the reset emial it should be within 10 minutes at most. That being said, it was mentioned yesterday that the reset password feature was broken again. I have not tried it so I can not say for certain.
