Us roaming talk text and data purchased by mistake wrong date
1Reek1
1 REPLY 1
will13am
@1Reek1, generally this service does not offer refunds.  However, goodwill may be considered in situations like this.  You could try explaining your case with the moderator team.  The moderator team can be reached via private message using this link.  Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
