How long does SIM take to activate?
Tariqq
Hello,
I subscribed to Public Mobile with a new Physical SIM card.
Its been more than an hour and my SIM is still not activated.
How long does it usually take to activate the SIM card after purchasing a package?
Thanks
Tariqq
My SIM has activated now.
Thanks  a lot to Public Mobile Customer Service.
Tariqq
Thanks, I have reached out to customer support via PM.
Socrates8567
@Tariqq wrote:
I have rebooted my phone multiple times, it is still showing as "Unregistered SIM"
You can try your sim card in a different phone if you can to re provision it. or you can reach a csa
Tariqq
@Tariqq
should be instant.
Reboot your phone with the PM sim card there (and make sure all other old sim cards are removed, old eSIMs are disabled)
also, try Reset network settings
if it still shows not connected, it is a sim card provisioning issue.  Easy fix for PM CS agent and you just need to engage them by direct message.
Private message CS Agent at:
Socrates8567
Hello.
Try rebooting your phone. You can also go into your settings and reset your network settings and then reboot. Try that first.
