09-12-2024
05:26 PM
09-12-2024
05:31 PM
computergeek541
I ordered a SIM card a week ago and I have not received it. I do not see a tracking number on the order confirmation email. Is there a way I can track the order? @CS_Agent Thanks!
Joining Public
09-12-2024 05:36 PM
@LucasZ9248 wrote:Since I have a Telus/Koodo Store 5 min away from me I might as well try my luck. Thank you very much!
Use gogle to see if there's a Mobile Klinik in your area as they also sell the PM sims.
09-12-2024 05:34 PM
@LucasZ9248 wrote:This indeed is taking much longer than I expected. I bought a one-month SIM at the airport upon arrival and was hoping to transfer my number over before that contract expires. Maybe I should just go buy a SIM card in a nearby Telus store and use what I ordered as a backup when it arrives? Would that work?
If they have them at Telus store, then yes...you can buy it then download the PM app to your cellphone to activate your new account.
09-12-2024 05:33 PM
09-12-2024 05:32 PM
Yes, that would work, but usually, it's only the corporately ran Telus locations that will have Public Mobile SIM cards. Frachised Telus locations are unlikely to have them.
09-12-2024 05:30 PM
09-12-2024 05:27 PM - edited 09-12-2024 05:30 PM
no tracking number supplied. It could take up to 3 weeks for it to arrive. Please..be patient.
added...use this link to message Customer Support if you haven't rec'd the sim after 10 business days.
