Cancelling SIM Card order
niraaz
I am new to Public Mobile. I was activating my subscription and I ordered SIM card although I already have one from my previous provider. Can I cancel that SIM card order and transfer this number to my plan @CS_Agent?
hairbag1
@niraaz wrote:
Thank you. But can I use the same number after activating the new SIM?
Yes...during the activation process, you'll be given opportunity to transfer your number from old provider to your new PM account. Don't cancel old account... It will automatically deactivate once you've successfully  transferred it to PM.
niraaz
Thank you. But can I use the same number after activating the new SIM card?
@niraaz
You can only use a PM SIM so best to wait until it arrives.
slusagm
Don't stop the PM sim card order,  you can't use sim card from your previous provider here.
hairbag1
@niraaz
nope. You need a Public Mobile sim in order to activate a new Public Mobile account.
hi @niraaz
sorry, you cannot use the sim card from your previous provider.   You need a brand new Public Mobile sim card to use PM service.  (yes, you need a sim card that match the carrier , cannot mix and match)
so, you will need to wait for PM to ship you the sim card and complete the activation by requestion porting your number into PM using  PM app
