How do I log in when my email (username) doesn't exist anymore
Allison6
How do I log in when the email (username) that I use to login with doesn't exist anymore?  I use the "forget username" link and submit my phone number.  The system then sends a reset link to my associated email... that doesn't exist.  Please help!
I am presuming there's a timeframe associated with the request @Phil_Adelphus
I doubt it wipes out the old username but the OP may be unable to log in within a certain time frame until the change request is either fulfilled or expired.
Mind you, this is just a guess.   The OP could test this out for us by trying to log in with their credentials and post the results here.
Can you try that,  @Allison6
@HALIMACS   I wondered about that, so even if the reset is not activated (due to not receiving the email) it still wipes out the previous username?
HALIMACS
@Allison6
Reach out to the customer support agents to update your username if the username reset link was already sent to prior email address ( which you couldn’t retrieve )
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
Phil_Adelphus
@Allison6   You should be able to log in with the old email because it's just a username, doesn't matter if it doesn't function unless you want to send the code to it instead of the phone.
