Referring friends points
SatsukiTakazak
I referred a friend with my code. How long does it to take to see in my account ?
@SatsukiTakazak  Did your friend get the one time $10 credit ? If not he will need to contact support to. Investigate
send a  private message   To CS_Agents
@SatsukiTakazak wrote:
I didn’t get text. Maybe friend didn’t put the correct code? In this case hoe can I contact public mobile?
Log in to your account / My Rewards / Refer-a-Friend / Details to see if there's any mention of his number. If not, he'll have to contact a Customer Service Agent to get your correct referral code applied to his account.
edited spelling
SatsukiTakazak
@SatsukiTakazak  You should get a cha ching text saying so your friend should see the $10 credit unavailable funds with in 72 hours of activation
hairbag1
@SatsukiTakazak
you should see it fairly quick. Did you rec the CHA_CHING text ? When did friend activate using your referral code ?
