How do I know if my phone will work on the Public Mobile network?
01-05-2015 04:24 PM - edited 01-04-2022 12:31 PM
Public Mobile works on following frequencies:
- For 3G use (UMTS/HSPA): 850MHz/1900MHz bands
- For 4G/LTE use: 1700MHz/2100MHz bands
- For 4G/LTE use: 700 MHz band
Which means most of the 3G,4G HSPA/ LTE phones that are compatible with these frequencies will work on Public Mobile. If your phone is locked to specific carrier, you’ll have to get it unlocked.
Phones compatible with Telus, Koodo, Bell, Virgin will work on Public Mobile network. All 3G, 4G phones from Rogers, Fido and ChatR are compatible and will work on the Public Mobile network.
To verify if you phone will work on Public Mobile network click here
Joining Public
02-03-2017 12:26 PM
@srlawren This one is a Xiaomi RedMi Pro. I only had my Note 4 for a year, so I'm trying to find something reasonably priced to replace it, which means having to look for a decent Chinese branded one.
Is there a map that I can see where bands 5 & 7 would be available?
Thanks for the help!
02-03-2017 12:25 PM
@sonician ah, yes. So again talk, text, and 3G (HSPA/HSPA+) data are going to work fine. You will get some LTE on bands 5 and 7 depending where you are at the time, but lacking band 4 is a bit of a blow for 4G LTE data. If having fast data is important to you, you might want to keep looking. If you're okay with the (slightly) slower 3G data most of the time, then this may well fit the bill. Out of curiosity, which phone is this?
02-03-2017 12:20 PM
@srlawren, I think this is what you need:
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
CDMA 800 / 1900
3G bands HSDPA 850 / 900 / 1900 / 2100
CDMA2000 1xEV-DO
TD-SCDMA
4G bands LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 38(2600), 39(1900), 40(2300), 41(2500)
02-03-2017 12:16 PM
02-03-2017 12:04 PM
@sonician 3G is great, you will get talk, text, and 3G data. Can you find the 4G specs listed in bands instead of in MHz?
02-03-2017 11:52 AM
Network:
2G: GSM 900/1800/1900MHz
3G: WCDMA 850/900/1900/2100MHz
4G: FDD-LTE 850/900/1800/2100/2600MHz
Thanks!
02-03-2017 11:38 AM
@sonician yeah make sure the phone has both 850MHz and 1900MHz 3G frequencies for compatibility. For LTE 4G data (if desired), look for band 4 at a minimum, with optionally any of bands 2, 5, 7, 12, 13, 17 being an asset (bands 2 and 7 being the most commonly available after 4, it seems)
02-03-2017 10:09 AM
Thank you for your reply, much appreciated. I will have to do some more research and be careful to note the band support.
02-03-2017 10:04 AM
02-03-2017 10:01 AM
Hello,
My Galaxy Note 4 died due to a bad memory chip on board.
I was going to pickup the Oukitel U13 as the specs are similar, hardware-wise, but was curious about the network support.
Here's the details:
Network:
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/900/1800/2100/2600MHz (Bands: 1/2/7/8/20)
Thanks!
02-01-2017 01:22 PM - edited 02-01-2017 01:23 PM
@deyneko1 wrote:Hi,
I am going to buy unlocked BLU Advance 5.0 on Amazon.ca for my daughter. It will be her first smartphone, so she can lose it etc. For this reason, my wife and I decided to buy a phone less than 100CAD.
But I found HERE that one person wrote the phone doesn't work with PM:
"This product was thoroughly disappointing. I purchased 9 of these for my business and I wish I would have done more research, this phone does not live up to expectations in any way. Terrible phone, claims it is unlocked but will not work on telus, koodo or public mobile. 2 people found this helpful. Was this review helpful to you?"
It is strange because I checked tech data and it should work in 3G and http://willmyphonework.net/ "said" it is OK with PM.
What do you think?
Yet if you look at other reviews you'll see the exact opposite:
Person A:
01-09-2017 01:40 PM
@computergeek541 wrote:I believe that many customers would be fine with a phone not having LTE much of the time, but to not have one of the 3g bands is asking for trouble, especially when the 850MHz band is often important for indoor coverage.
@malbrax I agree with @computergeek541's assessment completely.
01-09-2017 01:14 PM
@deyneko1 that is strange, the phone appears to be compatible. If you search the reviews for "Koodo" you can find a second review that says it didn't work with Koodo. This is definitely disconcerting, though I'm not sure why in this case.
To be completely honest, this is a VERY low-end phone, that came out nearly 4 years ago (April 2013), has a terrible resolution, VERY little storage (4GB--there would be almost none left for the user right out of the box), and only a half gig of RAM that will make running more than one application at a time a nightmare.
If I were honest, I wouldn't even buy this for a child. They are going to want to do things on it and be frustrated right away and continuously. If you want to keep the cost to a minimum due to potential for losing the phone, maybe pick up a used phone on craigslist?
01-09-2017 01:03 PM
Hi,
What do you think?
01-09-2017 12:33 AM
01-08-2017 06:57 PM
@malbrax only miminally. You will get some 3G talk, text, and 3G HSPA data on the 1900MHz frequency but you're missing the other core 3G frequency of 850MHz, and only band 7 of your LTE is compatible--and that will only get you some LTE data in certain areas of the country.
You could try, but I don't think you're going to be happy with the service on this phone, unfortunately.
01-08-2017 06:55 PM
01-08-2017 06:53 PM
Hello,
Will my phone work?
Injoo Max 3 LTE, not sure on the right version from the list
Thanks,
Network & SIM TYPE
2G: Yes, 850/900/1800/1900
3G: Yes, 900/1900/2100
4G: Yes, LTE 3(1800)/7(2600)/20(800)
Sim Type: Dual sim slot, Micro sim
01-06-2017 09:29 AM
01-06-2017 04:08 AM
@mumpstar wrote:Hello,
I have a Sony XPERIA XZ Dual F8332
which says it has the following bands:
- 2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only)
- 3G bands HSDPA 800 / 850 / 900 / 1700(AWS) / 1900 / 2100 - F8331, F8332
- 4G bands LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 17(700), 19(800), 20(800), 26(850), 28(700), 29(700), 32(1500), 38(2600), 39(1900), 40(2300), 41(2500) - F8331, F8332
- Speed HSPA 42.2/5.76 Mbps, LTE-A (3CA) Cat9 450/50 Mbps
- GPRS Yes
- EDGE Yes
The IMEI is being rejeced "Unknown" in the Public Mobile checker.
Will this work?
Thanks!
Public Mobile's IMEI checker giving a positive result is not a requirement for the phone to work. As you already know, there are errors in that database, and there are also missing IMEI numbers.
If the specifications that you pasted here are accurate, your phone will work fully. All UMTS and LTE bands that Public Mobile uses appear to be supported by your phone device.
Thank you computergeek541!
01-06-2017 12:28 AM
- GPRS Yes
- EDGE Yes
Will this work?
Thanks!
01-05-2017 10:48 PM
Hello,
- GPRS Yes
- EDGE Yes
Will this work?
Thanks!
12-20-2016 01:00 PM
@mishafljin wrote:Hi,
I have european Samsung J500FN
Quad Band 850/900/1800/1900
UMTS 850/900/1900/2100
LTE cat4 800/850/900/1800/2100/2600 (bands 1 3 5 7 8 20), TD-LTE 2300 (bands 40)
Is this device going to be okay?
Thank you
If those specs are accurate, voice services will work fine. Data services will also work fine in UMTS mode but for LTE, you're probably not going be conncted to that much of the time. Your phone is lacking LTE Bands 2, 4, and 17.
12-20-2016 11:26 AM
12-20-2016 09:42 AM
Hi,
Thank you
11-07-2016 12:03 PM
11-07-2016 11:58 AM
Thanks, I'm gonna buy a iPhone 6S that locks to Telus.
11-07-2016 11:35 AM
1) does it have the right network frequency support? Yours should yes.
2) is it either unlocked, or locked to Telus/Koodo? Yours fails this condition until it is unlocked.
11-07-2016 11:30 AM
I didn't get it.
you said " If your phone is locked to specific carrier, you’ll have to get it unlocked."
and also said "All 3G, 4G phones from Rogers, Fido and ChatR are compatible and will work on the Public Mobile network. "
What if I have a phone that is locked to Fido/Rogers/ChatR?
Thanks.
10-17-2016 11:22 AM
