How do I get into acct without this new eversafe
So I guess I lost my username to used to be JB456. Now it had me log in and make a new username.
Anyways. How do I fix this silly eversafe stuff?. I am out of the country and one of my lines I don't have access to the sim card and all eversafe wants to do is text me a code to sign up. I need that sent to my email registered on that account. Or can PM just turn off eversafe on accounts?..
Thanks... Darlicous ( if that's your username still lol.. I hope you are well)
@softech  thanks. Hope you're well. I resolved the issue did forgot password. Changed pass then had the option to do the code from eversafe through email. All is well. Take care
HI @Jb456 @Anonymous
It is now an easy fix to get the old id back, just need to engage support and you should it back in no time.
Message them here:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened.  CS Agent will reply to you
And see you back in @Jb456 tomorrow
@Anonymous
No you can’t login without confirming your login credentials but you can click on Trusted Device so you don’t need to the 2FA code ever time login.
@Anonymous  Contact support to get your old community ID back and regain access to your account .please
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
