5 hours ago
- last edited
4 hours ago
computergeek541
My username was "DrSaxMusic" but when I went to put that into a new screen, it said that name was already taken.
The system gave me "DrSaxMusic1" but I want my old name back.
4 hours ago - last edited 4 hours ago
@hTideGnow wrote:we were allow to change our community name easily ourselves. But someone abused it and keep changing names and then posted spam, hence PM took away the privilege
But, support agent can still help if it is a one time request and if it makes sense. So, message support agent and ask
So it seems that more was possible in the past. Also read that some lost gift data if they downgraded. I understand that now also downgrading plans is not possible. When I joined I did receive 5 free points and also a $10 account credit but no data was gifted. Possibly because my $15 plan does not include and data unless I purchase as I did with my $10 credit.
5 hours ago
The same thing happened to me when eversafe was implemented back in 2023. My original nickname was funpig.
I recently contacted an agent about it. They can switch you back to your old nickname/community account. However, any status or bravos would you have earned using your current nickname will be lost. I opted to stay with the current nickname until my help points had accrued. I may switch when I am less active.
5 hours ago - last edited 5 hours ago
@Wayworn it looks like a year ago it was possible ( through the website) under the Personal tab there was a sub-tab for Nickname but it no longer appears so it doesn't look like we can change it at the self-serve level but I'm sure an agent should be able to have access
So it is possible to revise one's community name?
5 hours ago
@DrSaxMusic1, since this is an account related issue you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
