04-20-2017 07:51 PM - edited 01-04-2022 01:41 PM
I just purchased the $20 add-on for the US talk, data and 250mbs of data for my upcoming trip to the states. Well, at least I think I did. How do I check if the plan has been activated? Currently, my account overview says "Available Funds: $20.00" so does that mean I have paid for the add-on or is that the amount I owe? Looking under my recent payments, I seem to have paid the fee so is that enough confirmation and that it is safe to assume that the plan is activated?
Any help is appreciated!!
04-20-2017 08:31 PM - edited 04-20-2017 08:33 PM
Thx @srlawren
As I always say we all support your suggestion about this 2step process 👏
04-20-2017 08:29 PM
@dagullibleasian you have received the correct response from @Samianauman: you have to go back into self-serve and buy the add-on again. I know it seems strange, and you will worry you will be charged again, but you won't. The first step only adds funds from your credit card to your self-serve account, where it shows now as available funds. Then you have to purchase the add-on from those available funds, which will bring that amount back down to zero.
If you hate this as much as I do, then after doing the second step, please take a moment to review and bravo (vote up) this idea to have it simplified: http://productioncommunity.publicmobile.ca/t5/Public-Lab/Purchasing-add-ons-should-be-a-single-step-...
04-20-2017 07:56 PM - edited 04-20-2017 08:28 PM
04-20-2017 07:52 PM - edited 04-20-2017 07:55 PM
