03-29-2023 09:21 AM
03-29-2023 01:09 PM
It keeps saying error processing request. Is it because I’m in the US? I can access my voicemail but I want to personalize the greeting. Thx
03-29-2023 10:14 AM
HI @MyraLivingston can you connect to the voicemail after pressing and hold on "1" ?
if you can , then just follow the prompt to setup new password
03-29-2023 09:36 AM
After you have activated your SIM, your voicemail is automatically ready to accept messages as soon as you add it to your account. It will play a default greeting until you set it up. Setting it up isn’t complicated:
- Hold down the ‘1’ key on your phone keypad to dial your voicemail access number. Calling your own 10-digit phone number will also bring you to your voicemail.
- When prompted, enter a password between 4 to 15 digits long. Try to make it hard to guess, but easy to remember. It will be more secure if you avoid using numbers that are repetitive or sequential such as ‘1111’ or ‘1234’.
- Choose whether you want to bypass your password when calling from your own phone.
- Record your name, and a personalized greeting.
- When you’re done, hang up to end the call.
03-29-2023 09:27 AM
03-29-2023 09:24 AM - edited 03-29-2023 09:25 AM
Very first time you have to call from your mobile phone and set voice mail up.
After that you can access it calling from your mobile (press 1) or any other phone calling access number.
