How can I unlock my public mobile voucher
05-04-2023
02:16 PM
05-04-2023
03:43 PM
computergeek541
05-04-2023 03:40 PM
Here is member contributed info on vouchers....
Or give us more info? Retailer? When did you purchase them? Amount? Did you make two mistakes and have not waited 1 full hour before trying again?
05-04-2023 03:31 PM
@ktamara- Specify what? Who are you replying to?
05-04-2023 03:27 PM
Can you specify more?
05-04-2023 02:39 PM
@6478529103 For your own protection ask customer support to change your Community username if that is a real tel. number. Here's a link to the chatbot for support: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
BTW, some vouchers, depending on where purchased, have several hours or more hold before the funds become available so you might need to try add it later which can be done either in your self serve account or by dialing 611 on your phone.
05-04-2023 02:26 PM
Unlock? So you bought a Public voucher from somewhere? Some places have some kind of delay until the voucher can be redeemed. Be sure to use the 12 digit set of numbers identified as PIN#. If you've been trying a few times then you'll need to wait an hour or so.
