Cannot send pictures/MMS
514mtl
Hi. In the last 2 days I have not been able to send any pictures.  My phone is not in the list of devices that Public Mobile no longer support. What can be the issue? Thanks.
12 REPLIES 12
514mtl
Thanks. I'll try that.
514mtl
Thanks, @softech. I have a Huawei Pro and I tried sending a pic using the home wifi and again with data on. I'll try your suggestion of resetting and see. Thank you.
I can't imagine you'd need to reset network connections to get MMS to work.
Have you tried rebooting your device and removing the SIM card and reinserting first?
@514mtl
If data, MMS and SMS enabled enabled. Try going to Messaging setting and clear the cache. Sometimes that helps.
514mtl
I have a Huawei Pro so it's not on the list of devices that are impacted by the MMS update. I'll try @softech suggestion of resetting and see if that'll work. Thank you.
Interesting @514mtl
What type of device do you have - an iPhone?  If so, are you using iMessage or MMS to send the messages?   If iMessage, the message is BLUE, if MMS it'll be green.
514mtl
Yes, everything else works... calls and texts, just cannot send pics.
@514mtl wrote:
Thanks @HALIMACS for your reply. I do have MMS enabled and data turned on.
OK... do other calling services work.   As in calling in and out and SMS services?
@514mtl you sure you are trying to send pictures using  MMS and not iMessage or RCS?? what if you turn on Mobile data or use wifi at home?
if you are really sending via MMS, try clicking Reset all networks and see if it helps.   But please note that it will delete your saved wifi as well and you just need to join those wifi back
514mtl
HALIMACS
@514mtl
Being able to send pictures simply needs MMS enabled.
Once it is, you can send picture texts.   You don't even need available data remaining to do so.
If you're using iMessage, that DOES need either data availability or wi-fi.
