How can I talk to a real agent
Corinne2026
Talk to agent
@Corinne2026
It would be quicker for us members to help you with common problem so what is your issue?
slusagm
The agents are all real, but you just need to open ticket. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:    https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox between 9AM-10PM EST (Mon-Sun), check here:     https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
