09-06-2019 11:41 PM - edited 01-05-2022 06:55 AM
09-07-2019 01:03 PM
IMO, you'd be better off considering upping your plan to the next data level for a month and see it that is more appropriate for you. It usually only costs you $5 or 10 and that's alot less than the 30 and a small price to pay to get data back. You can renew early, but it requires a moderator's help. Cannot be done through self serve.
09-07-2019 05:25 AM
@computergeek541 wrote:
@chukdefatey wrote:
@QuinnGirard wrote:Prices ?
Very Pricey but it's Full speed LTE and doesn't expire till it's all used up. What I find ironic is it's more expensive than the US Roaming Data add one. Just goes to show you the nerve of these Canadian Providers.
Unfotunately, even at those prices, that does not always mean full LTE speeds at Public Mobile. if the customer has a base plan that already has "3g" speed data, the add-on will also be at the same speed.
Are you sure about that? From what I remember from the early days. Canadian Data add ons are supposed to be Full Speed LTE. I know any bonus data offering that are offered time to time on new activation go with whatever the Plan speed is.
Absolutely certain
Add-ons follow the speed of the base price plan. This goes for bonus data add-ons and paid data add-ons. There's aren't any exceptions to this.
Oh wow. I stand corrected. Since that is this case that makes it even worse and even more expensiver.
09-07-2019 04:34 AM - edited 09-07-2019 02:09 PM
Absolutely certain
Add-ons follow the speed of the base price plan. This goes for bonus data add-ons and paid data add-ons. There aren't any exceptions to this.
09-07-2019 03:53 AM
09-07-2019 03:43 AM - edited 09-07-2019 03:44 AM
09-07-2019 03:36 AM
09-07-2019 03:05 AM
(thread moved to Plans and Add-ons category/not rewards-related)
09-07-2019 12:42 AM
Options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to send a private message to moderator. Moderator wait time is 2 - 3 days. If your next renewal date is 2 - 3 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $30 1GB data or $10 200MB data. Expensive option
4. If you are a subscriber on August 19 or ealier, you already got your free 1GB data/
09-07-2019 12:10 AM
The $30/1GB Data Add-on is a good gap filler but a terrible way to sustain heavy Data habits.
It would cost much less to upgrade your Plan to one with higher Data allocation. Or to find free WiFi.
09-06-2019 11:48 PM
If changing plans right now is not advantageous to you because of where you are in your cycle remember the add on rolls over til it runs out. So it's a little insurance til you figure out which plan with data meets your needs.
09-06-2019 11:46 PM
09-06-2019 11:45 PM
09-06-2019 11:43 PM
Change plans to a plan with more data.
09-06-2019 11:42 PM
Prices ?
