03-19-2019 04:31 PM - edited 01-05-2022 06:55 AM
Hello I have a question. I was wondering can we use a prepaid Visa for payment and get the $2 off on auto pay? It's one of those reloadable Visa cards
Payment
03-19-2019 05:42 PM
@bridonca wrote:If the prepaid Visa you are using does not work, you can get a Koho Visa card. It costs you nothing, and Public Mobile has been cross promoting it a couple of months ago.
Koho is really good. Had them for a while but never tried it on PM.
03-19-2019 05:40 PM
03-19-2019 04:48 PM
That really helped as it mentioned the company I went with and they say it works no problem
03-19-2019 04:43 PM
I found a related tread on same topic @ https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Setting-up-Autopay-using-Prep...
03-19-2019 04:40 PM
@sulagok wrote:Hi @tehowennathe ,
I think you should try to add the card as your auto payment, if it is accepted, then it surely should work. Otherwise, you may inquire from the moderators.
Just wonder as it's from that company that Public Mobile had partnered with a while back.
03-19-2019 04:39 PM
@tehowennathe wrote:Hello I have a question. I was wondering can we use a prepaid Visa for payment and get the $2 off on auto pay? It's one of those reloadable Visa cards
The only sure way to find out is to try it. You got nothing to lose just login to your account and try to add the card number.
03-19-2019 04:38 PM
Hi @tehowennathe ,
