12-31-2022
12:15 PM
12-31-2022
04:25 PM
computergeek541
Hello folks,
I have not received the holiday rewards message.
As others suggested, I have tried the chatbot but couldn't open a support ticket.
Thanks
12-31-2022 12:18 PM
first try to send YES2 to shorcode 4911
if you got back a reply saying they will add it, good
if not, then just open ticket with PM Support and they will add it back for you.
Please open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-31-2022 12:18 PM
Since you've done some reading have you then tried to send a private message?
What was the problem starting a ticket? I've had more success using the pin method rather than the login method.
12-31-2022 12:17 PM
@eljassine @First try texting YES2 4911 of that doesn’t work for you try my bottom link and have agent apply it manually for you @eljassine
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
