Holiday bonus
rongronlund
I have not received my text to send for my holiday bonuses. What can I do.
2 REPLIES 2
HI @rongronlund   don't wait, today is the last day, open ticket with CS agent and they will add them back for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@rongronlund @You can first try texting YES to 4911 , if that doesn’t work reach out to agent to have it manually applied for you @rongronlund
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
