Hi I can’t receive any calls and texts
Eui
Hi I can’t receive any calls and when I try to log into my app, it requires me to enter verify code by receiving on the phone, which I can’t receive so I’m stuck, unable to reach the customer service …
7 REPLIES 7
Eui
Horrible customer service. Can’t reach anyone
LouiseLee
Did you just transfer your number? I had the issue when I transferred because I took the old SIM out too early.
Try: Remove the old provider's sim card from the phone, then to turn the phone off and then back on and to test the calls, the text messages and the data.
Neil11
Ongoing issue for new activations.
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
Viikhj
Having the exact same issue as a new member
Rastin
No do not post your number this is a public forum.
You can get the code sent to your email. Under where you would enter the code you will see did not get code click on it to send to email.
You can private message PM here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
LouiseLee
Did you send a direct message to "CS_Agent"? I messaged regarding a number transfer issue and they replied within a couple of hours and had it resolved!
Eui
Btw I’m a new subscriber , should I leave my number here ?
