07-06-2022
05:10 PM
07-06-2022
05:16 PM
computergeek541
07-07-2022 12:51 AM
We can only help you if you respond and give us more details of your problem.
07-06-2022 05:46 PM
@raymondzhou122- I have found excellent response via private message. I have experienced 404's using the chatbot at the point of the submit ticket link. So it's why some people suggest both methods. You're fine. Yes the chatbot is the official proper way but if it 404's out then just private message them. So when answering queries just give them both.
07-06-2022 05:18 PM
Okay thank you for letting me know.
07-06-2022 05:18 PM
@raymondzhou122 wrote:https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
You can use this to private message an agent for help. This happened to me and they helped me port my number currently after switching from a different service.
Please be directing customers to use the SIMon chatbot to open tickets. Sending a private message in the above manner will result in the customer receiving slower service.
07-06-2022 05:18 PM
More details are needed.
How long have you been PM customer?
When this started to occur?
etc.
07-06-2022 05:16 PM
@tbeals744 wrote:im not receiving in coming calls I phone8
Did you just ask for a phone number to be ported to Public Mobile? In that situation, the incoming calls would be going to carrier of the old service until number porting has completed.
07-06-2022 05:16 PM
07-06-2022 05:15 PM
@tbeals744 did you just activated and request porting in number from another provider?
If so, a critical step in porting is to reply YES to a text from your old provider, did you complete that?
I will send you a number you can call to talk to porting team for live support, please check the Community inbox, envelope icon on top right
