a month ago
Switched from Fizz to Public. Got the confirmation email from Fizz and it's been more than a day. Can send outgoing calls and texts but dont receive incoming. Can I get some help?
a month ago
First, remove the old carrier sim card (or disable the old carrier esim),
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing therethere. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support to help. You can submit ticket by direct message:
a month ago - last edited a month ago
Did you reply to the text from Fizz confirming with YES you are porting over to PM within 90 minute?
If not then the porting wasn’t completed.
Contact a CS_Agent to complete the porting process.
If you did reply then reset the network settings on your phone.
a month ago
Did you reboot your phone
Check to see who your provider is
