Help
Gwiens
I’m phone does not call Canada from Yuma az
phone number is ### #######
18 REPLIES 18
Gwiens
Funny my husbands phone works down in Yuma with the 65.00 plan which I have also. Please help
dust2dust
I seem to remember a further complication with iphones and current OS is that the 2G GSM option is no longer selectable. I seem to think it can switch down but sometimes some areas won't work for that. Whereabouts are you? There is no T-Mobile in Alaska so since your phone does not have volte and talk only works on T-Mobile, T-Mobile has nothing for us in Alaska.
You can still text and use data on AT&T but you need T-Mobile and their 2G GSM for talk.
HI @Gwiens
iPhone 6 does not have VoLTE
you need to change back to T-Mobile and try using only 2G to make calls
Your husband's phone work better, could be because he has a newer phone
Gwiens
Changed my phone back toat&t
phone says your call has faiked
HI @Gwiens
after you change to AT&T, go back to network mode screen and make sure it is set to Automatic or LTE (4G), then try to make calls (or try data) and see if it works
Gwiens
I know how to change networks to t mobile or AT&T but how to I test at &t network lte /4g
Gwiens
I have an iPhone 6
HI @Gwiens
what phone do you have?
using T-Mobile is ok.  But if you like you can try to change the network mode to 2G and test
or you can use AT&T and use network mode LTE/4G and check
Gwiens
I manually changed my network to t mobile but now don’t have any sound when making calls
@Gwiens  What phone do you have?
Calling requires either volte enabled on the phone or using T-Mobile and their old 2G GSM.
mojorising
So I'm guessing the suggestions in this thread did not work?
Help - Community (publicmobile.ca)
HI @Gwiens are you able to manually connect to T-Mobile or AT&T?
Gwiens
My phoe ne receives texts and emails but no phone calls.  I am on 65.00 USA to Canada plan as we are in Yuma az currently.  my husband has the same plan and woks just fine. Help me plse
@Gwiens
The $65 US/Canada plan doesn’t require a US Roaming.
Go to your phone cellular settings and manually connect to T-Mobile or AT&T network.
Gwiens
My husbands phone works great down here  we have purchased the 65
plan
@Gwiens
to be able to call Canada from US, you need to buy US roaming add-on, did you get one? or are you on the Canada-US plan?
if not, then you will have to use other way to Call back Canada.  You can call it free using VoIP app TextNow,
@Gwiens
Please remove your personal information by clicking on the V in circle and edit or your will get spammed.
PM doesn’t have service in Yuma, AZ unless your have purchased a U.S. Roaming Add-on. Login to your account and make your purchase.
You can use WhatsApp on wifi for free calling and texting.
