Help me cancel my account
SJ14
2 REPLIES 2
hi @SJ14
first, remove the phone number.  This is just the Community and we are just customers like you
and for those accounts, did you activate them all today? you activated physical sim or esim?
make sure the old carrier sim card are removed.  If the old one is esim, disable them
and for the PM esim, make sure it is set as Primary and active (or Turn on this line is set).  Then try Reset Network settings
if you still cannot make them work, ask PM suppor to help or ask them to cancel the account for you
you can submit  ticket by direct message:
Chalupa_Batman
These are public forums, not private. Remove your phone numbers! Reach a CS Agent here.
