12-03-2022 09:28 PM
Hello,
Can someone please tell me how I can cancel one add-on purchase that's made by mistake? - Bought US Roaming data 1G twice due to the delay for the add-on showing up in my account.
Thanks in advance!
Add-Ons
12-03-2022 09:46 PM - edited 12-03-2022 09:46 PM
Does the self-serve show as 2 add-on purchases?
You shouldn't have been able to make 2 exact purchases of the same US Add On. Normally, one must wait 24 hours after the first one expires before a 2nd identical one can be purchased.
It's possible the 2nd purchase is showing as a 'pending' charge on your c/c and it may not actually settle to a fulfilled charge.
12-03-2022 09:33 PM
Thanks so much for your help promptly!
12-03-2022 09:29 PM
You can try contacting an agent.
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
- Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
