guest on account
12-03-2022 05:21 PM
my phone shows i have a guest on my account. i shouldnt have i cant see anything in my account here
My Account
12-03-2022 09:37 PM
phone was hacked? I would buy a new phone... no one knows how powerful that trojan is/was. even a factory reset might not get rid of it... if it's a Chinese brand phone it's probably at the hardware level
12-03-2022 06:06 PM - edited 12-03-2022 06:07 PM
@glenna check this
https://support.google.com/android/answer/2865483?hl=en
If you're the device owner
- Open your device's Settings app.
- Tap System > Multiple users.
- If you can't find this setting, try searching your Settings app for users.
- Tap the user's name.
- Tap Remove guest > Remove. The user will be removed from the list
12-03-2022 06:01 PM
Press your finger on the head labelled guest , until you see a little trash can. Then click on the little trash can to delete that unwanted guest.
12-03-2022 05:45 PM
12-03-2022 05:39 PM
shows 2 heads when i scroll down for wifi etc. i cant get rid of it. i was hacked last night. ip address changed passwords changed but its sti;ll there never saw it before
12-03-2022 05:37 PM
ikr. i was hacked last night i just finished changing ip addresses but guest is still there
12-03-2022 05:35 PM
when i pull down screen to access wifi, blue tooth etc. public mobile shows 2 heads. 1 says owner and the other guest.
12-03-2022 05:26 PM - edited 12-03-2022 05:27 PM
@glenna Turn off hotspot……..no other way to have a guest…..
12-03-2022 05:25 PM
@glenna can you post a screenshot?? not sure what you meant. I suspect it might be some device thing and not network related??
12-03-2022 05:25 PM
Can you provide screenshot of that 'guest'. Never heard you can have 'guest' on account unless it is your phone's feature.
12-03-2022 05:24 PM
@glenna Hi a guest on your account? Where do you see this?
12-03-2022 05:24 PM - edited 12-03-2022 05:26 PM
You shouldn't have any unwanted guests on your account.
Can you please be more specific and explain what you mean? Please.
