12-25-2022
05:56 PM
12-26-2022
03:15 AM
Dunkman
12-26-2022 09:53 AM
@NoImNotAJoey wrote:I'm horrible at remembering passwords. But I know my pm password .
you said earlier that you were not with PM yet. You said you want to switch to PM after
I'd like to get into my account and buy a new sim from the good company.you guys, and when it arrives switch too you right away
So, are you with PM?
If you are with PM and cannot login because of the 2FA and lost phone, you can try to get a new email address first, get a new free Gmail and don't setup 2FA. Then open ticket with PM support and ask them to help changing your email addressed used for My account to this new email address. Please open ticket with Chatbot:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
12-26-2022 05:03 AM
12-26-2022 05:02 AM
Can't log in with 2 fa on my account...lost old phone and can't get into my other emails yet for the normal recovery method
12-26-2022 03:31 AM
@NoImNotAJoey wrote:Yes I'm 100% a PM customer still
Earlier, you stated that you're with a different company. Which 2 factor authentication code are you asking about? Are you asking about codes sent by your bank or the code sent by Public Mobile to get into your Self Serve account to update the SIM card?
12-26-2022 03:18 AM
12-25-2022 06:50 PM
@NoImNotAJoey you don't go to My Account to buy sim card
Although you can buy sim card from PM online, I don't suggest you to do it, as it could take long for PM to deliver your sim card
So, please go to a Telus or Koodo store and buy from them in person. Or you can also buy from Amzon
https://www.amazon.ca/Public-Mobile-Card-Unlocked-Phones/dp/B07R6P5KBB
And you are NOT PM customer yet? if you are not PM customer yet ,Once you have the sim card, then you will activate your sim card here https://activate.publicmobile.ca/ and arrange porting
if you are PM customer, the you will login to My Account and tie the sim card to your exiting My Account
12-25-2022 06:46 PM
No new public mobile sim yet..with a different stupid company..I'd like to get into my account and buy a new sim from the good company.you guys 😉 , and when it arrives switch too you right away
12-25-2022 06:25 PM - edited 12-25-2022 06:26 PM
@NoImNotAJoey you lost your phone, bought a new one.
And you bought a new SIM card,too?
did you login to My Account and use "Change SIM card" to link the new sim card with the account?
Tell us what you have done with this new phone and new sim card...
