3 hours ago
Hello,
I need to cancel my eSIM / public mobile package. Trouble is, I have already deleted the eSIM off my phone. And when I try to login to my public mobile account it wants to verify me via my phone but I no longer have access to it. How do I go about cancelling my account when I can’t do this two factor authentication? I really need this cancelled.
thanks for your help in advance
2 hours ago
yes, if you have not "verified" your email after setup, the resend code option won't work. you need PM to help. please message them
2 hours ago
Heya
That Option doesn’t come up, only “resend code”
3 hours ago
@Britters73 Do you not see option that says “didn’t get code “ tap it and you should have option to send code to email instead and log in that way . If still no luck you can direct message support
