09-23-2024 04:29 PM
Should I get an add on or get a new sim while on the islands?
09-23-2024 05:53 PM
I’ll have to check about the Canada- US plan that you and others are talking about. Haven’t seen that as an option. Just Canada and then international texts
09-23-2024 05:52 PM
I’ll check but don’t think I have the US roaming. Thank you I’ll do the add on
09-23-2024 05:50 PM
Thank you I will look at the add on. I don’t have anything with us roaming.
09-23-2024 04:46 PM
@PeggI just got back from a trip in Europe and was perfectly fine with using the hotel's WiFi with apps like WhatsApp and whatever else I needed that worked off of WiFi. If you feel you'll need cell service you Public Mobile is covered in Hawaii through it's U.S. partners T-Mobile, AT&T and Verizon so you could get a roaming add-on for 15 days as has been mentioned
09-23-2024 04:34 PM
If your plan does not include US roaming, then you can purchase an add-on for 3 or 15 days. if your plan does have US roaming then just make sure it’s on when you travel to Hawaii.
To see the add-ons sign into My Account then click the “+ Add-Ons” on the main page or go to Subscriptions & Add-Ons scroll down then click Shop Add-Ons
https://myaccount.publicmobile.ca/en/account/manage/shop/addons
09-23-2024 04:31 PM
@Pegg wrote:Should I get an add on or get a new sim while on the islands?
Whether you wish to get a SIM card while you're in Hawaii is a choice you'll have to make after taking a look at the price of the wireless services there. Public Mobile does work in Hawaii if you havea Canada-US plan or if you have a US roaming add-on.
