11-11-2024
01:40 PM
11-11-2024
02:09 PM
computergeek541
Whenever I attempt to log into my account on my iphone, I am prompted to enter the 6 digit code received by sms and immediately after entering the 6 digit code the login page returns to the login state without proceeding.
Any ideas how to login into my account?
11-11-2024 02:08 PM
That is strange, sometimes when im prompted to enter the 6 digit code that i receive via text, i select for it to autofill from sms but it doesnt fill correct (only happens on public mobile for me). So i have to manually write the 6 digit code. Have you double checked you are entering the code correctly?
If yes and still not working, i would reach out to a customer service agent which you can do here:
11-11-2024 01:48 PM
@StephCVine wrote:I have tried this with no success
Dial 611 with your cell to hear current plan status.
11-11-2024 01:47 PM
@StephCVine Try with new browser window and try incognito mode / private mode or try the PM app instead if you been using website
11-11-2024 01:47 PM
11-11-2024 01:46 PM
Nothing is displayed after entering the code
11-11-2024 01:42 PM
try to cycle phone OFF, then On again and then retry PM log in.
11-11-2024 01:42 PM
@StephCVine When trying to log in do you see option says “didn’t get code “ ? Tap it and you should have option to send code to email instead . If still no luck get support to help
