Has anyone had problems using can, usa, mex plan? ?
Richard1231
While in Mexico, Has anyone used the new Can U.S. Mexico plan and does it work good?
@Richard1231
@Richard1231 wrote:
Mine kicks in on Dec 21, will see how it works then
Let us know how it goes.
Another PM customer just went to Mexico City and no major issues with usage of Mex roaming.  There are a few dead spots as expected in a major city.  Otherwise, no major complaints.  ATT is the partner carrier.
Richard1231
Richard1231
Im leaving tomorrow for Mexico. Didn't get plan changed on time, Will see how it works when it kicks in though.
Dunkman
@Richard1231
Looks like one person has used this service in Mexico.  No concerns so far.
Using ATT as partner
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-i-use-my-public-mobile-in-Mexico/td-p...
Dunkman
@Richard1231
As mentioned these Mexico plans were just released.  There is one member that I know that is heading to Mexico tomorrow with this PM plan.  Once I find out, I will try to update this post.
hi @Richard1231
it only has came out for 2 or 3 days, I doubt anyone got it and went Mexico yet.  So, definitely no one reported yet
but people on Telus used Mexico roaming with AT&T there without problem.
So, book a Mexican holiday now and you can be the first one report back about your MEX roaming experience
