07-04-2026 12:40 PM
is it just me? lately I cannot make any toll free calls. regular calls ok but not those 1800. I rebooted phone multiple times as well
07-04-2026 01:24 PM
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
07-04-2026 01:05 PM
thanks. I think it was roughly after I went US
07-04-2026 12:43 PM
Ask PM to reset the account
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
07-04-2026 12:43 PM
did you travel recently? this issue usually happened after people came back from trip.
you will need to engage PM support to fix it on the system. Please open ticket with PM support:
