11-26-2024 09:35 AM
We are visiting to mexico for about a week, would like to know if there any add-on that i can take so that my phone services work there too.
02-25-2025 11:55 AM
I'm confused. The Can-US-Mex plan means that I can send texts and make calls while IN Mexico.... but if you read the terms and conditions, it seems that may not be the case? It would be nice to talk to a real person to confirm this?!
01-12-2025 09:48 AM
Access your account and select Can.US.Mex. plans
01-09-2025 10:08 AM
Hi there - Can you guide me as to how to change from my existing plan to the can-us-mex plan? thank you
01-02-2025 03:46 PM
I believe you have to subscribe to the Can - US- Mex. plans which I have and work well . As to add-on not aware of any
12-19-2024 01:14 PM
I switched to the $35 Can-US-Mex plan for one month, and then I immediately chose a different $30 plan that will take effect on the renewal date (after I've returned from my trip). There's no guarantee that the cheaper plan you want will be available after you switch, but you can routinely change to less costly plans in my experience (multiple times now).
11-27-2024 10:03 AM
Did another speed test last night with 35mbs data in Mexico
11-27-2024 04:54 AM
I guess subscriptions can be changed anytime. Is that no more an option in PM?
11-26-2024 03:23 PM
@hTideGnow wrote:hi @charuguptamba you will probably get connected to AT&T. But could also be able to connect to other carriers there
There are roaming agreements with mulitple carriers, but the exact carrier used can differ based on the region.
11-26-2024 03:17 PM
11-26-2024 03:04 PM
I have not yet travelled rather will be travelling next month for 3 days so wanted to know the options for coverage.
11-26-2024 11:18 AM
which city you are in ? any 5G there? and which carrier you connected to? maybe try another one?
11-26-2024 11:15 AM
11-26-2024 10:23 AM
11-26-2024 10:20 AM
for a short trip to Mx, consider using WhatsApp to talk/text other WhatsApp'ers for free using local wifi. If you buy one of the currently offered Can / US / Mx plans...you won't be able to downgrade to a cheaper plan once you return home.
11-26-2024 09:56 AM
I am currently in Mexico using the 3 country plan $35 ,all is well for data and calls, Public is using the ATT system here
11-26-2024 09:42 AM
sorry no. Canada-US plan only work in Canada and US. If you are in Mexico, you need Canada-US-Mexico roaming plan. And too bad, PM does not have single roaming addon for Mex at this time
11-26-2024 09:40 AM
What if i take the Can-US roaming add-on, will that not work?
11-26-2024 09:38 AM
sorry, no roaming add-on for Mexico. If you need the service, you will have to go to Can-US-Mex roaming plan. And since you are there now, you will have to make Change now to change the plan immediately. But you might not get back your current plan later after you make a plan change now
