Getting calls in Europe
AudreyF
Hi, I'm not sure I get this right. I understand I can't make calls outside North America.
But if I'm in Europe, can people still reach me at my Public Mobile number, whether they're calling from Canada or from Europe?
Thank you
HI @AudreyF  No, you cannot.  For something like this, you will need roaming service but PM does not have roaming service in Europe
Get local data and phone sim card, it is cheap in Europe and easy
hairbag1
No you won't rec calls while in Europe.
Get a free voip app like textNow. You'll be able to send and rec calls / texts using wifi. If you buy a cheap data plan in Europe, you can also use it for Textnow to call most any US or Cdn numbers.
Outdoorsman
@AudreyF hi no your phone will only work in Canada or US with an add on sorry
dabr
@AudreyF   Sorry, no.  There's no PM service outside of Canada or US with a roaming option.
