03-26-2019 10:21 PM - edited 01-05-2022 06:59 AM
I was wondering if anyone using Public Mobile in Fort Erie, Ontario roams automatically over to the U.S. ??
03-28-2019 03:44 PM
Yes, l drive to Fort Erie sometimes and it does automatically switch to AT&T especially close to the peace bridge. All you need to do is to manually switch back to PM network from the settings.
03-26-2019 11:09 PM
@Sunshine21 wrote:I was wondering if anyone using Public Mobile in Fort Erie, Ontario roams automatically over to the U.S. ??
If that does happen, your calls won't be completed so there is no roaming charges either. You can manually set phone to select local tower.
03-26-2019 10:26 PM
@Sunshine21 - It's near the US border, so depending on tower placement, you could get picked up by a US tower. Could try locking in the network.
03-26-2019 10:26 PM
That can happen any time you're near the border. If the Public Mobile signal is very weak or the AT&T or T-Mobile signal is stronger, you phone might choose to connect to that network instead. Luckily, there are no pay-per-use charges at Public Mobile. To prevent your phone from connecting to a roaming network, you can manually set the network that you wish to stay connected to.
