Forgot Login Information
sabereh
I activate my sim 6 months ago and now unfortunately i forgot the email I used for my registration. I only have access to my number. Could you help me with login into my account?
sabereh
Yes, I did. I have activated auto-payment for this account. does that help?
@sabereh  if you setup your account 6 months ago, you must activated yourself online and you must have used an email address
But no worry , you can message support and they can look up the email address used for you
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
sabereh
Unfortunately Nothing! Maybe I have entered an email that I can't remember now. there should be a way to access the login information just only by accessing the phone number! the ai bot is awful. it gets stuck in a loop!
@sabereh - check your email's spam and junk folders. It likely ended up there.
sabereh
I tried  Forgot email link and it asks me for my number, after I enter my number, it says we sent an email to your email! but I checked all my emails and I haven't received any email!
Forgot password link doesn't help me because I don't know my email at this step,
Thank you for the third solution. I sent a message to CS agent. I hope this solves my problem
@sabereh
you can first try to Forgot email link  ( https://eversafe.id.telus.com/user/forgotemail?locale=en&ForceAuth=true  ) and then Forgot password link  ( https://eversafe.id.telus.com/user/forgotpassword?locale=en&ForceAuth=true ) on the login page there. They will send you the "hints" via SMS/email.
If that does not help, please open ticket with PM support
