07-02-2023 11:15 PM
hi- i want to change plan to a higher data, but can i also get back my original subscription after a month of trying a new plan? Thanks!
07-02-2023 11:23 PM - edited 07-02-2023 11:23 PM
@Mike231 beauty for PM is there is no contract, you can switch between plans all the time... as long as the plan you want to change over is available. So, YES, you can change any time. of course, PM has been changing plans a lot lately. So, be aware that the plan you are leaving might or might not be there a month later or so
And why making plan change, remember to use Change on Renewal if you want to schedule a plan to start at the end of the current cycle.
07-02-2023 11:18 PM
@Mike231 - changing plans is easy at Public Mobile. Ensure you choose to pick to "Change on next renewal" so that you don't lose out on funds already paid in this cycle, because there is no prorating the amount.
You can schedule to go back to any plan - AS LONG AS it is currently being offered in the inmarket plans in your My Account.
