Forget add referral code during registration.
AlanHQ
Hi,
I forgot to add my friend's referral code to my registration 15 minutes ago. Is there any way to add it into my account? just don't want to see his sad face. The referral code is xxxxx.
Edit by Dunkman
hi @AlanHQ agent usually will to manually apply it back. Just submit ticket with CS agent by message
Dunkman
@AlanHQ
You will need to contact customer service to help add the referral code
Send a private message to CSA through the following link :
P.S. I will edit out the actual referral code (against forum rules).
hairbag1
@AlanHQ
use this link to send that code to Customer Support, to add it to your file..
