My plan
siyuzeng
I want to confirm if I change my plan successfully by myself? (changed from $25 to $34 via text message).
hi @siyuzeng add to what @CS_Agent said, please so NOT post your reply here. Instead , send agent the answer to their direct inbox
CS_Agent
Customer Support Agent
Hello there!
Chalupa_Batman
Hi @siyuzeng
The way I was able to confirm that when I got that text message was to download the app. When I logged in, at the bottom left corner there was a plus with a circle around it. When I hit subscriptions, it showed there. It didn't show right away because it takes a day or so for it to register. That is how I found out. Take a look and see if it's there. If not, check back again tomorrow.
EDIT If you said yes, you should have got a confirmation message back. If you got that, you should be fine.
HI @siyuzeng  we are just customers like you and no access to your account
first , you have the service now?
then , check My Account by login using Incognito/Private/Secret mode on your browser and check Subcription & Add-on page for plan details, see if new plan there
if in doubt, submit ticket with Cs agent
HALIMACS
@siyuzeng
No one here can confirm that - we are just other customers like you.
Log into your self-serve and go to your subscription and add on section.
Your plan details will display there
