03-12-2021 07:09 PM - edited 01-05-2022 05:35 PM
Hello,
Kindly help understand ¬ For 15$ monthly plan, 100 Minutes Province-Wide Talk counted for Outgoing calls only OR Outgoing + Incoming calls?
07-25-2021 09:50 AM
03-13-2021 01:52 PM
Alright, thanks lot @darlicious
03-13-2021 01:51 PM
Perfect, thanks
03-13-2021 12:07 PM
To add to @hairbag1 's instructions....make your selection (tick "1") then scroll down and submit your selection/ payment and confirm. Then go back to your overview page and look for the add on to appear at the the bottom left hand side of the page.
03-13-2021 11:39 AM
Alright.. Thanks again @hairbag1
03-13-2021 11:37 AM - edited 03-13-2021 11:59 AM
@amitbhagat wrote:@hairbag1 that's perfect!!
This is what I was trying to search for from addons to add... Can you please help how to get it activated
Make sure you have $5 in Available Funds, then after you log in to your account, click Purchase Add-ons. Make your selection from the menu and you're good to go.
03-13-2021 11:35 AM
03-13-2021 11:33 AM
@amitbhagat...FYI, a good addition to plans with limited out-going calls would be the $5 / 500 minutes of Canada wide calling add-on. With that add-on on your account...if you run outta regular plan minutes, the add-on kicks in and you get 500 additional minutes of Canada wide calling...all for an addition $5. If you don't use those add-on minutes up, they just keep rolling over until you do use 'em..even if it takes several months or more.
The $5 /500 minutes of Canada wide calling add-on is a perfect addition to your current plan.
03-13-2021 11:32 AM
@Anonymous thanks!! I'm not out of the minutes yet.. Will need to check further
03-13-2021 11:29 AM
As a backup, purchase the $5 / 500 minutes Canada-Wide addon. It is great value, and stays on your account until used up. The Plan Minutes always gets used first each cycle, before the addon kicks in.
03-13-2021 11:29 AM
Thanks a ton @NDesai.. Much appreciated!
03-13-2021 11:28 AM
03-13-2021 11:28 AM
@HALIMACS thank you
03-13-2021 11:27 AM
@Anonymous, that might be possible
03-13-2021 11:26 AM
@LurganIeUk yes on the main page
03-13-2021 11:25 AM
@darlicious I still have balance minutes, so will come to know when reaches to 0
03-13-2021 01:09 AM - edited 03-13-2021 01:09 AM
Are the incoming minutes still counting or just from before March 11th? I just tried to see if one of the accounts I manage had incoming count against the 100 minutes it did not but there was system maintenance last night(Thursday.) The account had 8 minutes used on the counter. The daily usage showed 4 minutes of incoming and 4 minutes of outgoing to voicemail (3 minutes to set up voicemail and 1 minute to check messages.) Its possible they fixed the glitch last night?
I 800 ( toll free) did not register n the minute counter.
03-13-2021 12:34 AM
Thanks @RosieR
03-13-2021 12:34 AM
You are right @Camera4617
03-13-2021 12:33 AM
Thanks @esjliv
03-13-2021 12:32 AM
03-13-2021 12:31 AM
Rights @Anonymous
03-12-2021 10:40 PM
@amitbhagat wrote:I don't think, as my incoming call minutes are also deducted from 100 minutes limit... Can you please confirm? @hairbag1
Where do you see the deduction? On your main page? Have you checked your usage history...does it show a cost for inbound calls?
03-12-2021 08:27 PM - edited 03-12-2021 08:28 PM
Thanks @NDesai . That would be some serious suckage if they made it 100 minutes total. That would even take us back to the original $15 plan. Yuck.
@amitbhagat : Are you out of minutes? Do you have any calling add-ons? Would you be willing to call a Canadian toll-free number and see if it adds to the counter on the overview page? Just something less than a minute to add 1 to it. That's the counter that matters in case you might be thinking minutes are being counted down in the usage details pages.
03-12-2021 08:23 PM
I have asked for a confirmation on this. Possible it is not set up properly in the system or they forgot to edit plan details.
03-12-2021 08:00 PM
@RosieR wrote:@Anonymous you my be right.
I may just as easily be wrong too. 🙂
03-12-2021 07:52 PM
03-12-2021 07:50 PM - edited 03-12-2021 07:55 PM
@Anonymous wrote:@RosieR : It's my current theory that this provincial plan is not set up properly. Yes indeed of course it says unlimited incoming...but this customer and a few other customers that have picked up this plan since it came up have been seeing this problem.
@Anonymous is correct - there have been other folks who insist their 100 minute allotment is being reduced by not only outgoing minutes (as designed by plan), but also INCOMING calls.
So please follow prior advice and inform the moderators.
In the other users case, the moderators reinstated the complete 100 minute allotment, so I gather you should anticipate the same.
EDIT: Here's the thread re above:
Solved: Incoming call counts into minutes - Community (publicmobile.ca)
03-12-2021 07:40 PM
03-12-2021 07:27 PM
Hi @amitbhagat here is your $15 Plan. It includes unlimited incoming calls, which means that all incoming calls from across Canada is including in your plan. They are not charged to your 100 minutes.
RosieR
