Family member switching to public mobile from koodo pre paid
Tw1tch3d
I have a family member that is switching to public mobile from koodo pre paid, they have already purchased a SIM card and setup an account in-store at walmart with a temp phone number. From my understanding I've read that a MOD is required to port their Koodo pre paid number to their public mobile account.
They have yet to make a community forum login account or a self serve login account, just wondering what the required steps are moving forward? Should I have them make a community account to get in touch with the MODS to port their number over? Or should I have them create a self serve account. Any help would be great, thanks in advance
Tw1tch3d
Awesome, thanks to both of you for the quick responses. Hopefully I should be able to get this sorted out tonight! Thanks again
srlawren
@Tw1tch3d yes and yes.  They should have a self-serve account to be able to check their usage, buy add-on(s) when needed, etc.  But to get the port done, you'll need to get them a community account each and then contact the moderator team as @will13am noted.  You can read how to contact them via private message here if needed:  How to Get Help - Community
will13am
@Tw1tch3d, you could use the temporary number to set up a community account and then private message the moderator team to complete the number port.
