3 hours ago
Hello,
My daughters phone is unable to make a call or answer calls. It just drops. Any suggestions on how to fix this?
3 hours ago
I don't use PM. I can't change sim cards as my phone is a company phone
3 hours ago
no it's not fixed, I'm waiting for a response back.
3 hours ago
But you use PM too and it works on yours? you have an iPhone too? did you try swap the sim card and test?
3 hours ago
it's been giving issue for some time now but it worked before. this started within the last month or so. I do have a ticket in and waiting.
we also tried all the suggestions you said as well and it's still not working
3 hours ago
@PayPay try the SIM card in another phone, if the problem continues you should contact an agent by clicking on the orange circle bottom right of your screen and type: Customer Support Agent. They might be able to do an account refresh or reprovision your SIM card
3 hours ago
so, it is fixed now by iPhone support? what was the problem?
3 hours ago
We are in Ottawa. I tired rebooting and toggling the airplane mode as well as spoke with iphone support and had it fixed for less than a day.
3 hours ago
it worked before?
try to reboot it first. try Reset All networks
If you can , test her sim on your phone
Last, you need to ask PM to help
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
3 hours ago
@PayPay , are you located in Western Canada? There was reports of calling problems recently. Maybe the problem is still being worked on. Try rebooting the phone or toggling airplane mode.
