08-20-2024
11:20 PM
08-20-2024
11:45 PM
computergeek541
08-21-2024 03:12 PM - edited 08-21-2024 03:32 PM
@Wayworn wrote:I always assumed that once one transfers an account from a physical Sim to an E-sim the physical sim is no longer useable. However I am now confused after reading a post by an Oracle that suggests otherwise . Am cut and pasting this
Of course a previously activated and deactivated SIM card can't be re-used, but nothing in the first posts actually states that is was previously used. I am only saying that a physical SIM card can be moved around from device to device as desired. This thread was reconstructed and extracted from mutliple threads, and it's difficult to know what the OP is actually asking.
08-21-2024 10:55 AM
If you HAD service with PM and then cancelled it, account was deleted, then old sim is deactivated and cannot be used anymore, ever.
If you replace physical SIM with eSIM then physical SIM is deactivated and cannot be used anymore, ever.
08-21-2024 10:51 AM - edited 08-21-2024 10:54 AM
@Wayworn I'm pretty sure in this case the old physical SIM card is no longer usable since the eSIM has replaced it. SIM cards are a one-time use. Yes you can move them into another phone but once it's been replaced with another SIM card or eSIM that's it, it's done
The way I'm reading the original post, it sounds like the OP wants to know if they can have 2 device sharing the same number by virtue of one device having the eSIM and the 2nd device using the old (original) SIM card that was on the account, which cannot be done
08-21-2024 05:00 AM
If the eSIM and SIM are on the same account then no.
When you transfer over to eSIM it will not work.
08-20-2024 11:45 PM
@FlyerCAN wrote:if i convert to esim, can my physical sim be used in another phone?
The physical SIM card would be usable in any compatible device.
