Exceeded max login attempts
goodoaks
Tried logging in and had issues with google prefilling outdated password. Successfully reset password and now I get a message saying "Exceeded max login attempts."
How long do I have to wait until I can log in?
1 REPLY 1
@goodoaks   the current My Account has no acocunt lock.  So, all you reed to do is to close the browser and relaunch.  But try to use Incognito mode to login and see if it works
if nothing work, please open ticket with PM support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
First type "Forgot log in Information", then click "Contact Us", then click "Click here to submit a ticket ↗
Next, enter your Community login, then select "Self-Serve Password Reset" and click "Next". and follow the steps
2. if you have problem with Chatbot: Private message CS Agent at:
