Public Mobile app login is failing but browser works fine
bguhatha
Tried multiple login attempts through my mobile (Android) but it's failing with message "Something went wrong. Please try again later" in last few days.
Works fine in browser. Deleted and reinstalled the app but the problem persists with same error message even after mobile device reboot.
Any pointers or workarounds would be appreciated! Thanks in advance!
1 REPLY 1
TheSterlinger
Every now and then  that happens. Did you clear the data from the app prior to deleting it?
Go to the app, click storage and clear data and reinstall.
