Esim
02-23-2024 09:27 AM
02-23-2024 09:29 AM
yes, you can keep the same phone number with esim
but keep in mind, one major problem with esim is that it cannot be transferred between phones. if you get a new phone in the future or you wipe the phone, you have to pay $5 again to get a new esim
To rebuy new eSIM, First, download the app on your new phone, click ⊕ or ⧁ at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now. You can buy and install eSIM from there
02-23-2024 09:29 AM
@Ozner_bari - Yes, it will go over to the esim but if you decide to get a new phone, you'll end up spending another $5 to get your cell phone service to work as an esim. They are non transferable unlike the physical SIM card.
02-23-2024 09:29 AM
Yes, you just sign into you account and change the sim number.https://www.publicmobile.ca/en/ab/get-help/articles/change-sim-number
