Esim
Gury_604
Where can I get new qrcode to setup my eSIM again
@Gury_604
sorry, this is the disadvantage for ESIM.
Most providers have this charge for eSIM transfer. Physical sim is better, it is really one time charge only
Gury_604
But that’s waste of money
@Gury_604
iif the eSIM was already installed and you deleted or try to transfer to a new phone, you need to re-buy a new on using the app
download the app, click ⊕ on the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now.  You can buy and install eSIM from there
If the eSIM was never installed , then you can get the eSIM QR code from the welcome email or message support
JRod
@Gury_604
Each QR code is one time use so if you are trying to re-add or put the eSIM on a different device you will have to re-purchase an eSIM for $5. Go on to Public Mobile app on the device, go to subscription and add-on’s, and then near the bottom of the page is an option “Shop SIM Card Now”
