30m ago
Trying to get eSim. Downloaded the app, in the purchase or change sim tab, there is no eSim option. Only Sim for $10. Why?
8m ago
what phone do you have? Use the IMEI checker to check if your phone is eSIM compatible here:
https://www.publicmobile.ca/get-help/articles/volte
if it is, please also use the eSIM IMEI checker here to confirm if the phone is clean (if it has dual eSIM, check both):
https://www.devicecheck.ca/check-status-device-canada/
if the phone is compatible and the eSIM is clean, or then have PM to confirm what is the issue, maybe they can send you a eSIM QR code instead. Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
