08-23-2023 09:46 AM
I was with you guy 7 years ago I really liked the services I don't know I stopped using you guys.
What the difference between esim and the physical sim card
08-31-2023 03:53 AM
My phone has esim which is alot easier then having to buy plastic sim card and your not polluting the earth l.
08-23-2023 10:10 AM
Piffft
08-23-2023 10:10 AM
@dust2dust but I know @Handy1 still wants his all eSIM iphone 15 LoL
08-23-2023 10:08 AM
@hTideGnow- Handy1 and I will be the last stubborn ones standing with our antique phones rocking a real sim card until our devices are no longer supported for updates. 🙂
But no stinking iphone for me.
08-23-2023 09:54 AM - edited 08-23-2023 09:54 AM
HI @dust2dust
but the phone manufacturers might be all eSIM very soon and you have no choice 😞
08-23-2023 09:53 AM
They all come back 🙂 Maybe you left to get a subsidized new phone. Maybe this place did something you didn't like and you took off in a huff 🙂
I also prefer a physical sim. Until all providers can add, remove, move, keep alive, give away with the same ease as a card then I'll stick with the card.
08-23-2023 09:52 AM
HI @Shadow36
eSIM FAQ :
https://publicmobile.ca/en/ab/get-help/articles/esim-faqs
https://www.telus.com/en/support/article/esim-voucher
But my suggestion, if you do not need eSIM, stay the old way.
08-23-2023 09:49 AM - edited 08-23-2023 09:50 AM
@Shadow36 you dont need to change to eSIM if you don't need to
eSIM is something inside your phone to replace physical sim card. Some new phone are eSIM only and no longer have the slot for a physical sim card. It is convenient as you don't need to go out and buy a physical sim card if you want to activate quickly
On the other hand, with physical sim card, you can easily move it to another phone to test or when you have a new phone. With eSIM, you have to pay for a new eSIM each time you want to move to another phone or even if you have wiped the phone
08-23-2023 09:47 AM
Here is a good article on the difference:
08-23-2023 09:47 AM - edited 08-23-2023 09:49 AM
@Shadow36 E sim installs on your phone if compatible device . Physical sim you can take out of one phone and put in another phone . Me likes physical sim best to be honest
Adding with physical sim you buy it once and switch it between phones . With eSIM you need to buy a new one every time you changed devices 😞
