08-25-2023 02:46 PM
I thought my phone was Esim compatible but after purchase I can’t activate it.
How can I get a physical sim card for the plan I’ve purchased?
08-25-2023 02:57 PM - edited 08-25-2023 03:11 PM
@dlduval77 wrote:I thought my phone was Esim compatible but after purchase I can’t activate it.
@dlduval77 , I don’t know what phone you have but I have an iPhone 14 Pro & it shows in my cellular settings that it accepts eSIM (shows Add eSIM)! There should be something on your phone that shows whether or not it accepts eSIM. If you know it does send a private message to CS_Agent to ask for help getting it to work. Theres been several Customers that have received error messages when trying to install it that CS_Agents had to fix for them.
08-25-2023 02:54 PM
HI @dlduval77
what phone do you hvae? sometimes the error for eSIM at the end was incorrect. You can try to scan your QR code from the email and install the eSIM that way
if you need a physical sim, buy one from Telus or Koodo store and then just submit a ticket with agent for them to change it on your account
08-25-2023 02:50 PM - edited 08-25-2023 02:50 PM
just get a Public Mobile sim card from
Once you got the sim , message support here and they will update your the sim for you:
